Activity Forums Apple Final Cut Pro Dissolves causing jump in video
  • Dissolves causing jump in video
    Posted by Glenn Pniewski on September 22, 2020 at 2:22 am
    I must back up here and say that, though I have FCPX at work, I am working now on a project at home on FCP 7.
    I am mixing quicktime files and mp4 files. The .mov is my “base” track, and the mp4s are my cut-ins.
    However. . .the picture jumps during the transitions. I thought this might just be in playback, but when I exported the whole file out as a quicktime file, the jumps had become major GLITCHES in the video.
    Is it true what I am hearing that FCP 7 does not like mp4 files? (The codec on the mp4s are H.264 AAC, whereas the quicktime files are H.264 Linear PCM)
    Do I have to convert these mp4 files to something else? Or do I have to take the whole project to work and use FCP X?
    Glenn
    Glenn Pniewski replied 5 years, 11 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    September 22, 2020 at 2:30 am
    Yes. FCP7 does not like mp4.
    Also, what’s the frame rate of your timeline and incoming clips? FCP7 wasn’t very good at mixing frame rates, either.
  • Glenn Pniewski
    September 22, 2020 at 2:38 am
    29.97
    Thanks, Jeremy. I was afraid that was the problem; can these mp4 clips be converted to .mov files in MPEG Streamclip? Or is just closing the barn door after the horse got out?
  • Diego Barraza
    September 22, 2020 at 8:26 am
    It is a good idea to trans-code your footage for FCP7 as H.264 will give you a lot of hangups in my experience. Even better if you ditch the whole thing and work in FCPX, you will have less headaches in the long run
  • Glenn Pniewski
    September 22, 2020 at 2:13 pm
    Thank you both. As a test, I ran a few files through Streamclip, converting them all to Quicktime ProRes 422; put them it into FCP 7, and it “seemed” to work. But, yeah, I’ll be working after hours alot on that office iMac (FCP X) just so I can sleep nights. Thank you again, good to be back here with helpful and learned mentors ~ Keep safe!
