Activity Forums Adobe Premiere Pro dissolve transitions in PP CS3
  • dissolve transitions in PP CS3
    Posted by Jack Deren on January 2, 2009 at 3:53 am
    Im having some trouble with my dissolve transitions in PP CS3. When applying a center at cut cross or additive dissolve to a clip there is additional footage that comes in just as the fade approaches the next clip and then it does the same thing when the fade starts after the hard cut. this additional footage is not there without the transition and I cant seem to locate where it even comes from.
    I know its kinda hard to visualize but something is definately wrong here…Its not my rig either…. Im running a QX9650 on a Maximus Extreme Mobo with DDR 3 2GB 1800Mhz O.C. RAM and have the system liquid cooled. my PSU is also an 800 Watter so there is no issues with the system that Im aware of.
    thanks for the time! and please help!
    -JD.
    Eddie Lotter replied 17 years, 8 months ago 3 Members · 2 Replies
  • Vince Becquiot
    January 2, 2009 at 4:48 pm
    Do you have footage below the 2 clips being dissolved ?
    If so, it will mix in during the transition. That’s because in the middle of the dissolve, both clips have less than 100% opacity, same as if you manually keyframed opacity in both clips.
    What you need to do is either put a black video clip below the dissolve transition (New > Black video), or cut the footage below.
    Otherwise, try purging the render files.
    Vince Becquiot
    Director | Editor
    Kaptis Studios
    San Francisco – Bay Area
  • Eddie Lotter
    January 2, 2009 at 8:59 pm
    I suspect you don’t have enough handles. See: Transitions
    Cheers
    Eddie
