Dissolve transition problem with transparency
Hey everyone, first-time poster here, but I’ve been referencing these forums for years (Thanks for all the great information, everyone!)
This problem seems like it would have an obvious solution, but I can’t seem to find the right search query to answer it. When creating a dissolve transition between two clips, one of which has been repositioned so that there is a transparent area, whatever is beneath the transition shows through the transparent area of the repositioned clip when the transition occurs. In this particular case I have a photo with a horizontal pan applied to it, but I also often run into this problem with video clips.
Is there any way to made a dissolve transition that has a built-in matte? In the past I’ve gotten around this problem by applying all of the transformations that I need first, then once I’m finished adding a matte beneath the layer and turning the clip and the matte into a compound clip, then applying the transition to the compound clip. It seems like there should be a more straightforward way of doing this though.
