Activity Forums Apple Final Cut Pro Legacy dissolve problem
  • dissolve problem
    Posted by George Seven on October 27, 2010 at 1:28 am
    Every time I add a dissolve on my footage, the dissolve adds a high brightness level. That is really annoying.
    Does someone knows why is that?
    I’m editing a trailer from an avid mxf footage I imported on FCP 7.
    Jeremy Garchow replied 15 years, 11 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    October 27, 2010 at 2:11 am
    Fcp does not edit avid mxf media. You need avid for that.
  • Daniel Ludwig
    October 27, 2010 at 3:59 am
    Hi jeremy,
    that´s not correct if he has the MXF4MAC-plugin installed. then you could have native MXF within FCP.
    @George: are there any other AVID-Codecs that are installed on your mac? how did you import the MXF to FCP? are you using the MXF-plugin?
    cheers
    danny
  • Jeremy Garchow
    October 27, 2010 at 4:14 am
    And you think he has mxf4mac?
    Even if he does, it’s not rt.
    Please see the post above, it will clue you in.
