Activity Forums Blackmagic Design DisplayVideoFrameSync memory leaks problem
  • DisplayVideoFrameSync memory leaks problem
    Posted by Mauro Gattari on January 9, 2012 at 2:59 pm
    I’m trying to write a small C program that outputs frames to the card, but I’m experiencing memory leaks problems.
    The program is very simple, after having enabled video output:
    deckLinkOutput->EnableVideoOutput(bmdModeHD720p50, bmdVideoOutputFlagDefault);
    It starts outputting frames at 50fps within a loop in which:
    1. create an output video frame:
    deckLinkOutput->CreateVideoFrame(
    1280, 720, 1280*4,
    bmdFormat8BitBGRA, bmdFrameFlagDefault,
    &videoFrame);
    2. write raw data within the frame (just a pattern of RED or GREEN pixels)
    3. display the frame:
    deckLinkOutput->DisplayVideoFrameSync(videoFrame);
    4. release the frame:
    videoFrame->Release();
    videoFrame = NULL;
    The program works, but memory consumption grows fast (1MB per second) and I can’t understand why since I think I’m correctly releasing a video frame before creating a new one.
    Can anybody give me any help?
    Linux Ubuntu 11.10
    DeckLink Studio
    Drivers 9.0
    This is the whole source code:
    #include "simple.h"
    #include "DeckLinkAPI.h"
    #include
    #include
    #include
    IDeckLink* deckLink = NULL;
    IDeckLinkOutput* deckLinkOutput = NULL;
    IDeckLinkMutableVideoFrame* videoFrame = NULL;
    unsigned char* publicCreateOutputVideoFrame()
    unsigned char* outBytes = NULL;
    HRESULT result = deckLinkOutput->CreateVideoFrame(
    1280, 720, 1280*4,
    &videoFrame);
    if (result != S_OK)
    return NULL;
    result = videoFrame->GetBytes((void**)&outBytes);
    return outBytes;
    void publicDisplayVideoFrameSync()
    /* ULONG refCount = */ videoFrame->Release();
    videoFrame = NULL;
    void cleanUp()
    if (deckLinkOutput != NULL)
    deckLinkOutput->DisableVideoOutput();
    if (deckLink != NULL)
    deckLink->Release();
    deckLink = NULL;
    int setUp()
    IDeckLinkIterator* deckLinkIterator;
    HRESULT result;
    deckLinkIterator = CreateDeckLinkIteratorInstance();
    if (deckLinkIterator == NULL)
    fprintf(stderr, "A DeckLink iterator could not be created. The DeckLink drivers may not be installed.n");
    return 1;
    // Get the first DeckLinkCard
    result = deckLinkIterator->Next(&deckLink);
    if (result != S_OK)
    fprintf(stderr, "Could not obtain the IDeckLink interface - result = %08dn", result);
    goto bail;
    result = deckLink->QueryInterface(IID_IDeckLinkOutput, (void**)&deckLinkOutput);
    if (result != S_OK)
    fprintf(stderr, "Could not obtain the IDeckLinkOutput interface - result = %08dn", result);
    goto bail;
    bail:
    deckLinkIterator->Release();
    deckLinkIterator = NULL;
    return 0;
    int main()
    const int fps = 50;
    const int nrOfFramse = fps*60*1; // fps * seconds * minutes
    int i,j;
    unsigned int pattern;
    setUp();
    for(j=0; j nrOfFramse; j++)
    unsigned char* frame = publicCreateOutputVideoFrame();
    if (frame != NULL)
    if ((j/fps)%2==0)
    pattern = 0x0000ff00;
    else
    pattern = 0x000000ff;
    for(i=0; i<1280*720; i++)
    ((unsigned int *)frame)[i] = pattern; // AARRGGBB
    publicDisplayVideoFrameSync();
    usleep(1000000/fps);
    getchar();
    cleanUp();
    return 0;
    Mauro Gattari replied 14 years, 7 months ago 2 Members · 2 Replies
  • Joshua Helling
    January 16, 2012 at 7:28 pm
    Might be best to contact developer@blackmagic-design.com to get help with this issue.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
  • Mauro Gattari
    January 16, 2012 at 7:30 pm
    Yes,
    I already contacted the developers and they acknowledged the issue. They are working on it, I’m waiting for the fix release.
