The other primary way to do this, other than using masks, is to use a “track matte” — more specifically, an “alpha matte.” Here’s how you do it:
LAYER 1: a large number 4 (make it in photoshop, illustrator, or with AE’s text tool)
LAYER 2: your video
If you press the F4 key you’ll toggle between showing a bunch of check boxes with each layer, and a couple of drop boxes with each layer. The drop box to the right is for Track Mattes. For the VIDEO layer (layer 2), click the Track Matte drop box and choose the “Alpha Matte” option.
Immediately, LAYER 1 is hidden (eyeball turned off), and LAYER 2 is “cut out” to match wherever LAYER 1 had been visible. Adjust the position of LAYER 1 and you’ll see it updates where LAYER 2 is visible. Scale, rotate, reposition LAYER 2 and you’ll see it moving within the shape of the 4.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.com
This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
