Activity Forums Adobe After Effects Expressions Display Number from For() Loop
  • Display Number from For() Loop
    Posted by Mac Lad on June 22, 2018 at 1:53 pm
    Hi Peoples,
    First of all, I am new to expressions. My goal is to display numbers between 0 and given input i.e. “a” on a new line(one below other). I did success to display initial number but my For() don’t iterate.
    The code I tried is below for the source text
    var text= ” “;
    var i;
    var a=5
    for (i=0; i<=a; i++) {
    text = “n=” + i + “\n”;
    break;
    Kalleheikki Kannisto replied 8 years, 3 months ago 3 Members · 3 Replies
  • Dan Ebberts
    June 22, 2018 at 4:06 pm
    This probably isn’t exactly what you’re looking for, but it should get you closer:
    var txt= "n=";
    var i;
    var a=5
    txt += i + "\n";
    txt
    Dan
  • Mac Lad
    June 23, 2018 at 12:02 pm
    Thank You, Dan…! Some changes to expression, made it worked as I needed
    But still, don’t understand why we use “txt+=”.
    Below is the changed Expression
    var txt= “”;
    var i;
    var a=5
    txt += “n=” + i + “\n”;
    txt
  • Kalleheikki Kannisto
    June 23, 2018 at 2:09 pm
    “txt+=” is shorthand for “txt = txt +”
    If you don’t add to the existing text, the text gets overwritten with the value during each loop iteration, i.e. you only get the last value from the loop in the end.
    Senior Graphic Designer
