Activity › Forums › Apple Final Cut Pro › Display LUT in FCPX? Color Finale?
Posted by Joe Loria on April 23, 2017 at 12:43 amHey everyone,
Was thinking of ditching davinci for FCPX as editing/grading suite. However, I use the display LUT feature in resolve to see my colors accurately for grading. How/what would be the best way to use a monitor calibration LUT in FCPX? i.e: lightspace calibration/LUT creation > use the LUT as a layer in Colour Finale? Or is there a plugin or FCPX feature I am unaware of?
Thanks in advance
PS. I posted this topic in the “grading” forum as well. Not sure which forum would be best. Thanks.
Ben Neufeld replied 9 years, 3 months ago 4 Members · 9 Replies -
Noah Kadner
April 23, 2017 at 8:45 pmDepends entirely on the workflow- some camera LUTs are built in (ARRI Alexa e.g.) and can be toggled in the inspector. Others would require a 3rd party plugin to display such as https://www.motionvfx.com/mplugs-107.html
Noah
FCPWORKS – FCPX Workflow
FCP Exchange – FCPX Workshops
XinTwo – FCPX Training -
Joe Loria
April 23, 2017 at 9:30 pmHere’s my situation, I have a computer monitor (lg 31mu97), which claims 97% dci. From my understanding (and previous attempts) , I can’t simply calibrate this monitor using the on-display controls as I will never get an accurate result. Using a 3D LUT within my software is my best bet. Unfortunately, I’m on a tight budget at this point and can’t shell out another 1k for an external I/o device. My workaround for this was to calibrate my display using light space, creating a P3 LUT which I use in Davinci resolves “display LUT ” option. This allows me to do all my grading accurately within resolve. Wondering if there is a way to do this within FCPX. My apologies if I didn’t make my situation clear ☹ I’m fairly new to grading. 🙂
Noah Kadner
April 23, 2017 at 9:37 pmSure MLUT will- but you’re really shooting in the dark w that workflow.
Noah
Joe Loria
April 23, 2017 at 9:55 pmI am??? Could you elaborate please? Any info is greatly appreciated.
Noah Kadner
April 24, 2017 at 12:24 amWell it sounds like you are approximating a Rec709 output via RGB in place of a proper i/o interface. That’s not the ideal way to achieve a properly calibrated color grade.
Noah
Joe Loria
April 24, 2017 at 12:34 amIm lost lol. I here one thing on one thread and another here. Light space users told me they grade with a similar setup to mine, but now I’m not too sure. Thanks for the responses.
Francois Jean
April 24, 2017 at 3:19 pmSince you already have this computer monitor that you want to correctly calibrate, the only solution that i can think of is the use of a hardware LUT box … most of then are SDI so a 4K HDMI LUT box can be difficult to find…
You must use a calibrating device with this external LUT box to calibrate your monitor.
I did find an HD HDMI to HDMI LUT box…but I don’t know that brand:
https://www.lightillusion.com/eecolor_lut_box.html
This could resolve your problematic.Using LUT plugins in or above the timeline to try calibrate your monitoring is not a good option.
My two cents or less…
FRANCOIS
Joe Loria
April 24, 2017 at 8:54 pmThanks Francoise!
I saw your reply over on FCP as well, thanks for the response. It seems my options are limited and I misunderstood the equipment necessary for a good grade. Steve Shaw (creator of lightspace) over at light illusion said my setup was viable and plenty of people grade that way. However I’m beginning to think I should either purchase a monitor with internal LUT capability or purchase a decklink along with a 4K LUT box?
Ben Neufeld
May 19, 2017 at 12:38 amI use the same workflow though with an ultrastudio mini monitor, which is not capable of loading luts. Just tried using color finale in FCPX to load the display lut that resolve uses and put it on an adjustment layer above my whole timeline, works fine.
Ben
