Activity › Forums › Adobe After Effects › display fireworks
display fireworks
Posted by Jim Cooper on October 26, 2011 at 10:57 pmI have what I think is a neat idea but I need some help. I would like to take several different videos that I have of display fireworks and merge them into one video. I would like for it to be flv. Is it possible to make the background transparent on each video and then merge. I’m thinking filter the black into the transparency? I have the full cs5 suite. Also how do I deal with the individual sound tracks. Any help is appreciated. Thanks
Jim Cooper replied 14 years, 11 months ago 3 Members · 8 Replies -
Walter Soyka
October 27, 2011 at 12:08 am[jim cooper] “I’m thinking filter the black into the transparency?”
You can experiment with different layer blending modes [link], or you could use Red Giant Software’s free Knoll Unmult effect [link] to make the black transparent.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Jim Cooper
October 27, 2011 at 1:36 amThanks Walter, your information is very helpful! I will post back after further work is completed.
Roland R. kahlenberg
October 27, 2011 at 1:56 amAs Walter has suggested, Knoll’s Unmult does a good job. You should however, crunch the input blacks so that a wider area of near blacks are turned into pure black areas. Do this prior to applying Unmult.
And upon generating a matte with Unmult, you may want to finesse the edges further. For this, Levels, set to Alpha mode with some tweaks over the input blacks and whites.
HTH
RoRKIntensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer -
Jim Cooper
October 27, 2011 at 4:17 amWalter, I did what you said and it works perfectly, Thank you very much!
Jim Cooper
October 27, 2011 at 4:20 amRoland, Thank you for the additional info, I will incorporate your suggestions into the project, they will help produce a more vivid end product! I’ll keep you updated!
Jim Cooper
November 3, 2011 at 6:23 pmOk guys, the info to make the fireworks have a transparent background was great, when I play 3 different fireworks together in “AE” It looks like they were shot off at the same time! the only problem is I would like to space them out in terms of distance from one fwk box to another. in other words right now they are shooting from the same location on the screen. I want to spread them out across the screen to give an even more realistic view of how I shoot a show. I have tried to use Adobe Premiere. Should I bring the edited video from “AE”. So far it doesn’t display them together. I also treid it in Sony vegas pro and it works somewhat correctly. Any advise to get the same effect in an editor as I did with “AE” Thanks
Jim Cooper
November 3, 2011 at 6:33 pmOk guys, the info to make the fireworks have a transparent background was great, when I play 3 different fireworks together in “AE” It looks like they were shot off at the same time! the only problem is I would like to space them out in terms of distance from one fwk box to another. in other words right now they are shooting from the same location on the screen. I want to spread them out across the screen to give an even more realistic view of how I shoot a show. I have tried to use Adobe Premiere. Should I bring the edited video from “AE”. So far it doesn’t display them together. I also treid it in Sony vegas pro and it works somewhat correctly. Any advise to get the same effect in an editor as I did with “AE” Thanks
