Activity Forums Adobe After Effects Display CSV group name as sourceText?
  • Display CSV group name as sourceText?
    Posted by Andrew Marston on June 29, 2020 at 9:27 pm
    I’m trying to display the name of a csv column as text by using expressions to link to the data’s group name, but can’t seem to get it. I thought the expression should be as follows, but it returns an error which reads “Static data node not found at input path. Found node type: Group data node.” Any ideas?
    footage("Weight2020 3 People.csv").dataValue([1])
    I can display the actual cell data (in this case numbers) using the following expression, but not the name of the array which I’ll use to create a label for a graph.
    footage("Weight2020 3 People.csv").dataValue([1,0])
    Andrew Marston replied 6 years, 2 months ago 2 Members · 2 Replies
  • Filip Vandueren
    June 29, 2020 at 10:00 pm
    I don’t think you can extract them from the footage.
    However, if you add that csv-footage to your comp as a layer, you can get to it like this:
    thisComp.layer("data.csv")("Data")("Outline")(1).name
    note that (1) will give you the first column name, it is not 0-indexed.
  • Andrew Marston
    June 29, 2020 at 11:34 pm
    Thanks so much!
