Activity Forums Adobe After Effects Expressions Display array in text source
  • Display array in text source
    Posted by Clement Dubois on October 7, 2021 at 1:29 pm
    I don’t know if it’s possible, but I want to display selected array properties in multiples text source.
    The idea is to paste mutiples numbers in an array, for exemple : [75, 60, 40]
    And in 3 text layers, select which one will be displayed.
    I could do it manually but, I need to do it for 20 text layers, so I wonder if it can be automatic.
    Dan Ebberts
    replied 4 years, 11 months ago
    2 Members · 5 Replies
  • Dan Ebberts
    October 7, 2021 at 9:49 pm
    I’m not sure at all if this is what you’re asking, but if you want a layer’s visibility to be driven by an array, you could use an opacity expression like this:
    array = [75, 60, 40];
    array.indexOf(index) > -1 ? 100 : 0
    and then only layers 40, 60, and 75 would be visible. (Note that this requires the JavaScript expression engine).
    If that’s not what you’re after, please provide more detail.
  • Clement Dubois
    October 8, 2021 at 7:37 am
    Thanks Dan,
    I’ll be more specific about my project.
    I’m working on a ranking system, so I wonder if it’s possible to write each points of each teams in a text source with an array, and pick the array value we want to display to text layer one by one ?
  • Dan Ebberts
    October 8, 2021 at 12:51 pm
    Ah, OK. Each of your points layers would need an expression something like this:
    txt = thisComp.layer("text with all data").text.sourceText;
    myIdx = parseInt(name.split("_")[1],10)-1;
    eval(txt)[myIdx]
    This assumes that the points layer’s name is in the format you’ve shown: “team.points_n”, where “n” minus 1 becomes the index into the array.
  • Clement Dubois
    October 8, 2021 at 2:30 pm
    Thanks for your reply.
    I pasted the expression, and try few things but nothing worked.
    my layer “team.points_1” shows nothing.
    Also I’m starting to learn Ae expression so I don’t understand “parseInt” and “eval”… 😅
  • Dan Ebberts
    October 8, 2021 at 8:44 pm
    Hard to say what’s wrong without seeing your project. The expression did work for me when I set it up though.
