Activity Forums Adobe After Effects Displacement map
  • Displacement map
    Posted by Ross Ishikawa on April 24, 2015 at 8:02 pm
    I’m trying to use a displacement map to create a jiggly line effect on a shape layer or an Ai file. I followed a couple of tutorials about it, but when I reference the displacement map with the shape layer I want to affect, there isn’t any change.
    Or rather, the only change that happens is the shape layer is displaced 5 pixels over, per the Max Horiz & Max Vert displacements, instead of those values affecting the degree of jiggle.
    Does this method work for shape layers and imported Ai files?
    Thank you
    Ross Ishikawa replied 11 years, 4 months ago 1 Member · 2 Replies
