Activity › Forums › Adobe After Effects › Displace Z Space with luminance map/displacement map
  • Displace Z Space with luminance map/displacement map
    Posted by Mathijs Luijten on June 18, 2012 at 8:36 am
    Hey guys,
    I am trying to create a ‘wave’ effect for a grid. To make this I want to take the luminance of a fractal noise and connect the percentage between white and black to the Z space of each seperate part of the grid. Also I want to connect the opacity of the shadows to the luminance percentage.
    Could someone please help me out with it? Cause since every part of the grid is a different shape I can’t easily use trapcode form…
    Mathijs
    Chris Bobotis replied 14 years, 3 months ago 3 Members · 3 Replies
  • Mathijs Luijten
    June 18, 2012 at 8:37 am
  • Darby Edelen
    June 18, 2012 at 7:01 pm
    It’s hard to know exactly what kind of displacement you’re hoping to achieve from your description. Depending on what you want to end up with the answer could be any one of these:
    FreeForm AE – bundled with AE CS5 & CS5.5, my understanding is that it’s no longer bundled with CS6. Can displace a single layer in 3D using a displacement map. Warps the layer.
    Card Dance – standard AE plugin. Cuts up a single layer into many cards and allows you to displace or rotate them based on layer maps. Wouldn’t warp the cards, just change their apparent 3D position.
    Expressions – could allow you to displace the position of several layers based on the luminance of another layer. Wouldn’t warp the layers, just changes their 3D position.
    Darby Edelen
  • Chris Bobotis
    June 18, 2012 at 7:28 pm
    Thanks for chiming in Darby. Agreed it is hard to tell what effect, exactly, Mathijs is going for. Mathijs please elaborate.
    Darby you are correct. FreeForm is no longer bundled with CS6 but FreeForm V2 is available for CS5 + CS6. Same features but much, much faster. See: https://www.mettle.com/freeform-v2/
    Cheers,
    Chris
    mettle.com
