Activity Forums Avid Media Composer DISK_INVALID_FILENAME_SYNTAX when Decomposing sequences
  • DISK_INVALID_FILENAME_SYNTAX when Decomposing sequences
    Posted by Roman Hankewycz on September 28, 2011 at 5:09 pm
    Hello,
    I’m conforming a project for online and when I try decomposing reels i get this error message DISK_INVALID_FILENAME_SYNTAX.
    The weird thing is if I make copies of the sequence and delete groups of clips so that each sequence contains a batch of clips from the original, I can successfully decompose each sequence. Meaning that at the end of this operation I end decomposing each clip in the original sequence. The problem with this method is that I end up with some clips decomposed multiple times.
    Any thoughts on what might be causing this issue?
    Thank you,
    roman hankewycz
    harbor film company // colorist
    Jeff Greenberg replied 14 years, 11 months ago 2 Members · 1 Reply
