Activity Forums Adobe Premiere Pro “Disk Write Error” problem
  • “Disk Write Error” problem
    Posted by Pjoconnell on August 24, 2005 at 5:52 pm
    I’m using Premiere Pro v. 1.5. I get the following error message for no apparent reason:
    Disk Write Error: Verify drive connection, available disk
    space and disk access privileges. Then save, close and
    relaunch project.
    This happens only when I import a .wav file. If I ignore the message and go on editing, nothing unusual seems to happen; edits are good, SAVE etc. works, projects seem fine. The HD works fine, I have almost 2 GB space, and I can SAVE, PRINT, CLOSE, OPEN, etc.
    Anyone have thoughts about what’s happening? Is there anything I ought to do?
    (I haven’t tried another .wav file, since I’m working with this one (for backgrounds) on a project with a number a varied versions.)
    THNX/PJO
    Steven L. gotz replied 21 years, 1 month ago 2 Members · 1 Reply
  • Steven L. gotz
    August 24, 2005 at 6:14 pm
    Perhaps there is not enough room to conform the audio. 2GB of storage isn’t enough in the scheme of things to count for much. You need a LOT more than that for almost anything.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
