Activity Forums Apple OS X Disk Warrior question
  • Disk Warrior question
    Posted by Phil on December 7, 2005 at 8:43 pm
    I just bought Disk Warrior and was wondering what is the best way to install this program onto my Hard drives, including my boot up drive.
    Will this install format my drives and erase the current information on them?
    Dual 867, 2G RAM /
    OS 10.3.7 / QT 6.5.2 / FCP 4.1.1
    David Bogie replied 20 years, 9 months ago 3 Members · 3 Replies
  • Gunleik Groven
    December 7, 2005 at 11:35 pm
    Congratulations!
    You’ve just got yourself one of the best pieces of software ever made.
    To fix your sstartup volume, you’ll either have to boot from the CD or have another volume/disk/partition with a system on it and DW.
    For all your other disks/volumes/partitions you kan run DW from your startup disk.
    Instalation is as easy as drop’ing the app where you ant it + registering it, and off you go.
    The fun thing about DW is that it basically works very vell. Has saved my b… a number of times.
    Gunleik
  • Phil
    December 8, 2005 at 5:43 pm
    Thanks! I installed it and it works great.
    Dual 867, 2G RAM /
  • David Bogie
    December 10, 2005 at 4:29 am
    I always like to ask the question:
    “why did you buy Disk Warrior?”:
    and
    “What other disk maintenance tools do you have and use?”
    bogiesan
