Activity › Forums › Adobe Premiere Pro › “Disk Full” error message HELP!
  • “Disk Full” error message HELP!
    Posted by Fathom18 on December 8, 2006 at 9:19 pm
    Hello, first I’d like to say I love these forums, I am a new member, and everyone seems to be very helpful.
    My Issue:
    I am an avid video gamer, and I record my game play footage with the program “Fraps”.
    I recorded about 30 segments ranging from 400k-4g in size per file. I recorded at 1280×1024 resolution in game. My settings in Fraps were 60 fps (which is useless I’m told) and Full Screen.
    I like to make videos of my game play and share with my community, I used to use Vegas, but I recently bought PP 2 for cheap from my school. I bought Fraps and PP2, so there is no issues with it not working, because of hacks or w/e.
    Anyway I created a project, custom settings for 25 fps 1280×1024 and the 1. ratio that is square settings (sorry not at my computer with pp2 for correct terms).
    I start working on my project, it is 18 mins in length, has audio and a bunch of video segments, which I cut drastically from the original. I am happy with the video, so I go to render it.
    I click on file, export, movie.
    I click on settings/custom.
    I make sure it is at 1280×1024.
    I chose my compressor, Divx.
    I chose my audio compressor, AC-3.
    I click ok and save it to my desktop.
    After a while, I get an error “Disk Full”
    I’ve tried uncompressed for both audio and video.
    I’ve tried Xvid.
    I’ve tried default, seems I can not get past this error message.
    I need some help please! If this can be fixed, if not, is there a way to render the pp2 file in another program?
    Computer specs:
    cpu – Core 2 Duo Xtreme 2.9ghz
    mb – Asus Dh delux
    ram – 4gb ddr2 800
    gpu – Radeon x1950xtx
    2 – 80GB raptors in Raid 0
    I read somewhere here, that fat32 can cause this and not enough ram can as well. I have 4gb and im on NTFS. Thanks for the help guys/gals.
    Mike Velte replied 19 years, 9 months ago 3 Members · 2 Replies
  • Blast1
    December 9, 2006 at 3:53 am
    [Fathom18] “2 – 80GB raptors in Raid 0”
    Are these the only drives you have on your system? is the raid partitioned into segments?
  • Mike Velte
    December 9, 2006 at 11:53 am
    If you captured 60 fps and export at 25 fps wont your finished video play at less than half of real time??
    1280 x 1024 = 1.3 million pixels X 24 bits per pixel = 31 million bits or 4 megabytes per frame or 240 Megabytes per second or just over 1 TERABYTE for uncompressed…DISK FULL.
    I dont think Premiere will export Divx or Xvid even with the compressor installed on your system, but even if it did, the file size would exceed the codec limit of 4 GB (non Open DML codecs)….DISK FULL.
    Even if it did, I dont think your computer could decompress the Xvid or Divx codec smoothly.
