Activity › Forums › Apple Final Cut Pro › Disconnect video from audio
  • Disconnect video from audio
    Posted by Greg Ball on August 10, 2018 at 4:45 pm
    So I’m cutting some interviews, and I’d like to have the interview sound start under broll footage before we see the person speaking. I’ve detached the audio from the video, but when I try to delete the video the audio is deleted as well. It still looks like they are still connected, because if I move the audio the video comes with it.
    How do I keep the audio and lose the video?
    Greg Ball, President
    Ball Media Innovations, Inc.
    https://www.ballmediainnovations.com
    Mark Smith replied 8 years, 1 month ago 4 Members · 5 Replies
  • Michael Hancock
    August 10, 2018 at 4:50 pm
    Are you sure you detached the audio, and didn’t just expand the audio component on the timeline? Select the video and if it selects the audio too then it’s not disconnected.
    You can right click a clip and choose “Detach Audio” to truly detach it, but be aware that you cannot reattach it to the video and there are no sync markers.
    Michael Hancock
    Editor
  • Greg Ball
    August 10, 2018 at 5:24 pm
    Yes, I right clicked and used DETACH AUDIO
  • Michael Hancock
    August 10, 2018 at 6:20 pm
    Then the audio might now be a connected clip to the video, if the video is in the Primary Storyline.
    If that’s the case, select the video clip and use the Delete key on the keyboard that’s above the arrow keys, not the Delete key next to the + key (and above the \ key). This will delete the video and replace it with a gap, leaving your audio in place (and now attached to the gap clip).
    Michael Hancock
    Editor
  • Jeff Kirkland
    August 10, 2018 at 9:32 pm
    Just wondering why detach the audio instead of putting the b-roll above the clip on the primary storyline and merging that down to replace the video at that spot?
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Mark Smith
    August 11, 2018 at 11:53 am
    Or you could expand audio components and J or L cut . You can roll back the video portion in a J cut, leading with the audio and back fill with B-roll as required. Once you detach audio as noted by a previous post , the audio is detached and there is no click or command to re atttach audio back in its original sync postion to the video.
