Activity › Forums › VEGAS Pro › Disc Cam
  • Disc Cam
    Posted by Dan Sherman on January 19, 2006 at 11:04 pm
    Posted question about DVD-RW disc used in Sony Handycam earlier this week.
    Vegas would not recognize it. Then I found out, thanks to Edward T., that the client on the other side of the country hadn’t bother to “finalize” disc.
    That is done and, as recommended by Edward T. I rendered it to .avi.
    It looks pretty bad! Quality is poor. Have i done something wrong here.
    Or is marginal quality something we can expect with this format.
    Ted Snow replied 20 years, 8 months ago 4 Members · 4 Replies
  • Gary Kleiner
    January 20, 2006 at 1:05 am
    You’re starting with a very compressed Mpeg2 file. The first question is, how does it look before converting to avi? The second question is WHY are you converting it to avi?
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Dan Sherman
    January 20, 2006 at 3:34 am
    “I meant to pull the MPEG2 import onto the timeline and then render it to DV-AVI. Now just delete the MPEG2 import and edit using the new DV-AVI file.”
    This was Edward’s suggestion form earlier.
  • Edward Troxel
    January 20, 2006 at 3:38 am
    DV-AVI is easier to edit than MPEG2. However, you can directly edit the MPEG2 and then do your final render. Either way, the render to DV-AVI should NOT look worse than the original. There has to be more to this picture somewhere.
    Edward Troxel
    JETDV Scripts
  • Ted Snow
    January 20, 2006 at 7:17 pm
    I think these cams are made for the consumers who want to just be able to record to the cam disk and play it back on their home DVD player. They are not made for editing. I have a friend that has one of these DVD based cameras and he says he hates it. Some must like them though since there is a market for them.
