Activity Forums Apple Motion disappearing parts of a layer when going from motion to fcp
  • disappearing parts of a layer when going from motion to fcp
    Posted by Catherinev on November 9, 2007 at 2:13 pm
    I’ve created a small animation in motion with different layers. (One is a still of film stock, the second layer are my videos scaled down to fit on top) this whole item moves together from the distance into frame. It looks fine in motion, and it looks fine in final cut pro if I just look at the movie without putting it into the time line. But as soon as I put it into the time line and render it, differnt random parts of the bottom layer (the film stock) dissapear.
    As I am a begginer in motion I wonder if there is something very simple to do. Should I export my movie from motion before reimporting it into fcp?
    Thank you for you help
    Noah Kadner replied 18 years, 10 months ago 2 Members · 1 Reply
  • Noah Kadner
    November 9, 2007 at 4:09 pm
    Probably some transparency in the Motion project- export as ProRes. Make sure your Motion frame size matches your FCP sequence.
    Noah
    Unlock the secrets of the DVX100, Apple Color and now the HVX200!
    https://www.callboxlive.com
