disappearing drive?
OK, i’ve been a cow lerker/member for about a year… i’ve posted twice in that amount of time, now two in one day!
here’s the deal:
i have an enclosure that has two SATA drives in it. when i begin my work day, the computer only sees one drive, it’s the drive on ‘channel one.’ so i check my DISK UTILITY and sure enough, there’s only the channel one drive to be seen. so i open SYSTEM PROFILER and my G5 sees the card (Sonnet X-Tempo) as well as the one drive that DISK UTILITY sees. so i check the enclosure and all lights are showing systems are a go. sooo…
…i shut down everything and reconnect the cables, double check the drives (they’re hot-swappable) and make sure everything is there and OK. then i start up the G5 and and only one drive is to be seen… this time it’s the drive on ‘channel two!?’ no i didn’t swap the drives or the cables and the external enclosure is all green. then the DISK UTILITY & SYSTEM PROFILER confirm all of what’s in this paragraph! so where’s the other drive?
also, i had a card in that PCI-X slot before getting the sonnet to my knowledge that shouldn’t be causing this problem.
i’m sure it’s a simple thing, but i couldn’t find anything similar in “search posts.” any ideas on what the deal is? i’d like to get my raid going!
hep’ me, hep’ me… i be hyp-mo-tyz’d!!!
thank you,
e3
e. eric johnson iii
eric@lillcreates.com
lill creates: founder/executive producer
Water Channel: producer/virtual set operator
