Activity Forums Adobe After Effects Expressions disappearing backslashes when posting code?
  • disappearing backslashes when posting code?
    Posted by Peter O’connell on August 22, 2008 at 6:56 pm
    Hi, a couple threads back I posted some code that looks fine when I click ‘Preview Post’ at the bottom of the screen, but then when I submit it to the boards all the backslashes get removed. Is there a workaround for this?
    Pete
    Dan Ebberts replied 18 years ago 2 Members · 1 Reply
  • Dan Ebberts
    August 22, 2008 at 8:24 pm
    Just use a double backslash. The preview will still show both backslashes, but there will only be one in the actual posting. Then if someone copies & pastes from the post they only get the one, which is what you want.
    Dan
