Activity › Forums › Apple Final Cut Pro Legacy › disadvantages to editing with the “unlimited RT”???
Posted by Micah Ginn on March 22, 2007 at 8:48 pma buddy just came and showed me how my rendering/preview days are over cause with unlimited RT you can look at all your renders before rendering them.
is there a catch to this? like eating up memory, high lock up rate, anything???
thanks in advance,
micah ginn
Bret Williams replied 19 years, 6 months ago 7 Members · 9 Replies -
Tom Wolsky
March 22, 2007 at 8:54 pmDropped frames in video and audio during playback. The more complex the timeline the more you’ll get dropped frames to the point at which it’s unviewable, but you can play through Motion projects, LT projects, animations, anything.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Scott Davis
March 22, 2007 at 8:54 pmYour rendering days are not over. Lessened yes, over no. There is no drawback that I know of.
Tim Baker
March 22, 2007 at 10:02 pmOne thing that I have found…to keep from so many “dropped frames”…go under the Sequence menu to Render Only then click Mixdown this does something to your audio…not sure what, but it has helped in the past if I was getting a lot of the dropped frames.
Kevin Monahan
March 22, 2007 at 11:33 pmTim, it mixes down your audio.
FCP has two modes:
Unlimited RT for working with FCP when roughing in FX
Safe RT when you need to check qualityKevin Monahan
Take My FCP Master’s Workshop!
fcpworld.com
Pres. SF Cutters -
Bret Williams
March 23, 2007 at 12:07 amI haven’t touched SafeRT since it was released. SafeRT is no different from Unlimited RT except unlimited will TRY to play as best it can. Whereas safeRT gives you much less real time than your processor can actually handle. It plays it “safe.”
Since it’s best to render everything anyway before output, I always work in unlimited.
Andy Mees
March 23, 2007 at 4:02 amony thing to be wary of eith Unlimited RT is if you are playing out live from the timeline.
for example, if you use a Matrox MXO or some such to bypass the conform process, and crash record to a deck or play live to a sat. feed, then you need to remember that your effects are unrendered. -
Bret Williams
March 23, 2007 at 5:42 amBe wary of it with SafeRT as well. I don’t care what the timeline says about not needing to render things like jpegs, it always does. Render everything. Mix down everything. Output via either print to tape or edit to tape.
