Activity › Forums › VEGAS Pro › Disabling Video Resample By Default
  • Disabling Video Resample By Default
    Posted by Julian Tang on September 4, 2026 at 2:19 pm
    I think the title speaks for itself. You add a video/image into Vegas Pro and render it as a video file, only for the frames to be motion blurred much to your annoyance, so you have to go back and manually disable resample for everything and render the video again. Does anyone have a solution on how one can disable resample mode forever every time you boot up Vegas Pro?
    Silviu Negoita
    replied 3 weeks, 3 days ago
    2 Members · 1 Reply
  • Silviu Negoita
    September 4, 2026 at 3:01 pm
    You can change the default behavior in VEGAS Pro by going to Options > Preferences > Video and checking the resample settings, depending on your VEGAS version. If there isn’t a global option available, you may need to use a script or extension to automatically disable resample on newly imported clips.For most projects, I’d also make sure your project frame rate matches the source footage, since resampling is mainly noticeable when the frame rates don’t match.This might also help: https://www.youtube.com/results?search_query=VEGAS+Pro+disable+smart+resample+default
