Activity › Forums › VEGAS Pro › disabling resample
  • disabling resample
    Posted by Grzegorz Kwiatkowski on November 9, 2011 at 7:59 am
    Is there any way to ‘disample resample’ on all clips by default? Smart resample is a very annoying feature that causes ghosting. Anyway, what is smart resample for? When is it useful?
    M
    Grzegorz Kwiatkowski replied 14 years, 10 months ago 4 Members · 4 Replies
  • Nigel O’neill
    November 9, 2011 at 3:09 pm
    Are you sure you are not experiencing an interlacing issue? Check your deinterlace method under project properties. If you are delivering to DVD, it should be set to blend or interpolate.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Thomas Roell
    November 9, 2011 at 5:21 pm
    The interlacing effects. Is there a recommendation what should be used if there is some slow moving action intermixed with some fast moving action ?
  • Jim Greene
    November 9, 2011 at 5:54 pm
    Grzegorz, be sure your project settings match your source footage because the resampling can also have this behavior if the project is not correct.
    -Jim.
  • Grzegorz Kwiatkowski
    November 14, 2011 at 10:38 pm
    Sometimes I use different footage from different source in one projects. Resampling should be disabled long time ago by Sony. It’s strange they haven’t done it.
