Activity Forums Adobe After Effects Disabling multiprocessing for RAM previews
  • Disabling multiprocessing for RAM previews
    Posted by Jared Flynn on November 17, 2010 at 4:09 pm
    Hi all,
    Is there a way to rig AE such that multiprocessing is enabled for rendering, but not for RAM previews? I have a large project that takes forever to save, and as such RAM previewing takes forever to start caching frames. I sometimes disable multiprocessing to fix that, but then I’ll forget to turn it back on when I go to render my scene overnight. Next thing I know I wake up the next morning and my render’s still not done, because multiprocessing is off.
    I’ve dug through all the preferences and I can’t seem to find a way to specify such a thing, but I really hope it exists because it’s awfully irritating to wait upwards of two minutes for a RAM preview just to get going!
    Jared Flynn
    Motion Graphics Designer / Lead AE
    Lone Wolf Documentary Group
    Jared Flynn replied 15 years, 10 months ago 2 Members · 3 Replies
  • Walter Soyka
    November 17, 2010 at 4:13 pm
    With regard to the RAM preview delay — what version of AE are you using? Have you installed the latest updates for your version?
    If you need to keep multiprocessing off for your RAM previews, you could can use Lloyd Alvarez’s BG Render script for all your rendering. It has an option to use multiprocessing which is independent of AE’s setting.
    Walter Soyka
  • Jared Flynn
    November 17, 2010 at 4:47 pm
    Hi there Dave,
    I think the culprit is that my project makes heavy use of both CS5’s Roto Brush and Foundry’s CameraTracker plugin, both of which I’ve found to be massive performance killers (I presume because of all the keyframes they generate). My other projects that use those tools less or not at all tend to perform SIGNIFICANTLY better.
    My specs shouldn’t be the problem– I run AE CS5 (10.0.1.19) on a Lenovo Thinkpad W701 with a 1.6Ghz hyperthreaded Core i7 proc (8 logical cores) and 16GB of very quick RAM, as well as a 1GB, 96-CUDA core nVidia Quadro FX 2800M. Windows 7 Professional 64bit.
    That said, my multiprocessing settings might be less than optimal. I grabbed them from some advice I read on AE Portal News. A little more modest than my original settings (which essentially handed my entire system over to AE if it so chose):
    Installed RAM: 15.9GB
    RAM reserved for other applications: 6GB
    Installed processor cores: 8
    CPUs reserved for other applications: 4
    RAM allocation per background CPU: 3GB
    Actual CPUs that will be used: 2
    It’s too bad there doesn’t seem to be a way to designate what gets the multiprocessing treatment… I can look into scripts, and boy howdy in the meantime I’ll be filing a feature request!
    Definitely let me know if my specs or settings raise any flags for you though; I’m always game to try some new configs in the interest of squeezing a bit more excellence out of my kit!
    Thanks in advance,
    Jared Flynn
  • Jared Flynn
    November 17, 2010 at 5:26 pm
    Thanks again Dave!
    It’s true, I definitely sacrifice some significant upgrade options running on a laptop (I’m pretty sure my RAM is maxed out at the moment, though I can jockey for a few proc upgrades from what I’ve currently got, as well as a twice-better Quadro if I ever have the money). For the moment it’s really essential that I be extremely mobile with my work, and to that end I can definitely say this Thinkpad beats the pants off the other kits I researched hands down.
    That said, rest assured I’m using what power I can muster from this wee beastie to save up for a killer desktop. 🙂
    Jared Flynn
