Activity › Forums › Adobe After Effects › Disabling Layer Properties.
  • Disabling Layer Properties.
    Posted by Smith Smith on October 14, 2016 at 10:14 am
    Hey All,
    I’ve created a template of a Calendar for the company I work.
    There are some elements of the template that I don’t want to be altered, more specifically the SCALE of some layers, is there a way to disable the SCALE property but keep the POSITION. Usually I hide these layers if I don’t want them altered, but they need to move some elements around depending on location but the Scale needs to stay the same.
    PM
    Roei Tzoref replied 9 years, 11 months ago 2 Members · 1 Reply
  • Roei Tzoref
    October 14, 2016 at 5:08 pm
    [Penri Mainwaring] “There are some elements of the template that I don’t want to be altered, more specifically the SCALE of some layers, is there a way to disable the SCALE property but keep the POSITION.”
    you could use an expression to “lock” any value. for scale you can use [100,100] and once you do, any changes to the scale won’t reflect to the layer as long as the expression is active.
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
