Disabling a hierarchy for one frame
I have a rabbit set up in a hierarchy & pretty much everything is attached directly to the torso. In one frame I’d like to flip the torso 180 degrees to snap my line of action when he hops. The problem I’m having is bc everything is attached to the torso, when I try to rotate it the whole rabbit rotates. I just want to snap the torso in the opposite direction for that one key frame. Is there any way to disable the hierarchy for the torso for the one frame while keeping the arms, legs, head, etc. in the same position?
thanks, jennifer
