Disable Opacity Control
Posted by Renato Gyuris on April 16, 2019 at 2:23 pmIs there any way to disable the opacity control area on the timeline.
I usually when I would like to drag a clip I click on the area what changes the opacity. So instead of drag a clip, I change the opacity.George Dean replied 7 years, 5 months ago 5 Members · 11 Replies -
George Dean
April 16, 2019 at 3:04 pmRenato, as far as I’m aware there is no way to turn it off. If someone else knows I’m all ears!
Increasing the height of the track may help provide more area for the mouse pointer to grab and avoid hitting the opacity line, but that comes with other problems like taking up too much real estate on multi track projects.
On the other hand, my feeble memory thinks I once read a user came up with a work around, but I didn’t follow up on it and cannot find the link. Could it be my memory is playing tricks (very possible), or perhaps someone will have a solution!
Best Regards……George
Graham Bernard
April 16, 2019 at 3:32 pm[Renato Gyuris] “Is there any way to disable the opacity control area on the timeline. “
Been using VP since 2002, never heard of one. BTW, it’s never ever been an issue for me.
* Grazie
Cameras: Canon XF300 + PowerShot SX60HS Bridge -
Dimitrios Papadimitriou
April 16, 2019 at 3:38 pmI have a similar problem when trying to reduce clip volume and grabbing the audio envelope instead. But to try and help you with your problem I do not know a way. You could lock a clip to the timeline while would disable the opacity slider but then you cant move the clip till you unlock it. So my best work around would be working with the selection edit tool instead of the normal edit tool. You can still click on and move clips, it will disable the on clip buttons/sliders so if you want to go into pan crop or fx etc you would need to right click and select them.
George Dean
April 16, 2019 at 4:32 pmIn addition to Dimitrios’s suggestion about the selection edit tool, and my suggestion to increase the track height, you can also double left click on the timeline vertical slider (far right) which will collapse the tracks. Then the opacity bar is not visible and not an option. I often need to use this to gain display real estate on the timeline. Double left clicking the timeline vertical slider again will toggle back the track height to default settings.
Ole Kristiansen
April 16, 2019 at 5:03 pmIf you use the right button on your mouse to drag a clip – then you will not have a problem with the Opacity !
Best,
Ole -
George Dean
April 16, 2019 at 6:44 pmThank you Ole, that is what I remember, just didn’t remember!!!!
April 16, 2019 at 9:31 pmI think what Ole or I suggested is probably the best way to go, just gotta decide which one adds the most annoyance.
Renato Gyuris
April 17, 2019 at 6:44 amThank you for your help!
The best solution for me is increasing the height of the video track.
I need to see the audio track. Almost after every cut, I crossfade (only) the audio track and I can’t do it with the selection tool.
Dragging with right click shows me a menu (move here, copy here…) I use dragging about a thousand times a day so always click move here is worst than sometimes click on opacity control.
Maybe it’s an issue for me because I use it for work. I have to work fast. And that’s why I sometimes miss the click.
