George Dean
April 17, 2019 at 3:14 pmRenato, as you favor the larger track height for your workflow, if you are not aware you can change the default height.
Increase the height of a video track to your preferred size. Right click in a blank space of the track header and select ‘Set default track properties’. Leave the check mark features as they are (unless of course you want to change one), and just press ‘OK’. That will save the height adjustment as your new default. So, whenever you add a new track, add another clip it will be the new height size default. Same when double left clicking on the track vertical slider (far right), double clicking will collapse the tracks and double left click will then expand the tracks to your newly set defaults. If you ever want to return to the installation defaults, go to ‘Set default track properties’, check the box ‘Restore original defaults’, click ‘OK’ and you are back. You probably already know about this feature, but if not, just a thought for you.
Best Regards……George
