Activity Forums Adobe After Effects Disable AE 2017 project conversion warning
  • Disable AE 2017 project conversion warning
    Posted by Kirill Skorodelov on November 11, 2016 at 11:33 am
    Hi all, does anyone know how to disable a warning when you open a project made in older version of AE if it is possible at all? I know it’s a standard warning which existed forever in but for my workflow reasons I’d like to disable it. I upgraded to AE2017 and of course all the projects created earlier in AE2015 are opened with this warning.
    Thanks a lot in advance,
    Kirill.
    Roei Tzoref replied 9 years, 10 months ago 3 Members · 3 Replies
  • Roei Tzoref
    November 11, 2016 at 4:57 pm
    I never heard of a way to disable it. as a workaround you could just save the project again over the original and now it will be CC2017 and not produce a warning when opening.
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Michael Szalapski
    November 14, 2016 at 4:31 pm
    I would recommend against saving over it. It probably won’t cause an issue, but it’s always better to be safe than sorry. I mean, I usually use the increment and save feature more than necessary too! I figure it’s just better to increment the file name after any big changes and I’d do the same in this instance.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Roei Tzoref
    November 14, 2016 at 4:57 pm
    definitely you should create backups for your projects. usually if I want to stay organized and create templates I would not use the increment method. but to keep organized I would create a folder called “Old” and save other versions.
    Roei Tzoref
