Activity › Forums › Adobe After Effects Expressions › Disable a layer at a specific time?
  • Disable a layer at a specific time?
    Posted by Rabhw1 on May 13, 2007 at 4:52 am
    Hi, I’m new to expressions and I’ve tried my best to find out how to do this…I see there is a property called active which returns a 1 if the layer is active and a 0 if it is not.
    The second question related to this is since this is a general layer property, where do I add the expression? (In other words, which “stopwatch” do I alt-click on and enter this expression?)
    I’m trying to disable a layer at a given time. Lowering the opacity isn’t an option unfortunately!
    Any help would be greatly appreciated!
    Ross
    Filip Vandueren replied 19 years, 4 months ago 3 Members · 2 Replies
  • Lord Scales
    May 13, 2007 at 2:46 pm
    Well, try changing the In and the Out Points to disable your layer. It is one alternative. But if it is not posible, I can’t help because I could connect a Checkbox Control (Effect/Expression Controls/Checkbox control) to the active switch, but I was unable to do the inverse.
    The stopwatch is in red:
    Image Hosted by ImageShack.us
    Lord Scales
  • Filip Vandueren
    May 13, 2007 at 6:36 pm
    active is a read-only property,
    so you can ask if a layer is active (it’s eyeball is on, and the time is between it’s in- and out-point)
    But you cannot assign an expression somewhere to ‘click’ the eyeball for you, or move the in- or outpoint.
    why is opacity zero not an option ?
