Activity Forums Sony Cameras Directional mic…
  • Directional mic…
    Posted by Shane O’brien on July 6, 2009 at 2:49 am
    The EX1 I rented did not come with a directional mic. I’m assuming I should go back and get one? I’m assuming the built in mic is not brilliant… Cheers.
    Dean Sensui replied 17 years, 2 months ago 2 Members · 1 Reply
  • Dean Sensui
    July 6, 2009 at 8:04 am
    I use an Audio Technica 4051a with a furry Lightwave windscreen. Supported by a Lightwave mic mount. Works great.
    The later versions of the Lightwave windscreen has shorter fur, so if you’re going to be working in gusty conditions I’d get a Rycote.
    I also reinforced the Sony mic mount. It’s very weak and guaranteed to break. Where the screws go through holes slender pieces of plastic. I beefed up the voids with fiber-reinforced epoxy when one of the mic mounts broke and neither have broken since then.
    Dean Sensui — Hawaii Goes Fishing
