Activity Forums Adobe After Effects Directional blur at edge of frame issue
  • Directional blur at edge of frame issue
    Posted by Graham Macfarlane on March 8, 2011 at 7:45 pm
    In AE CS5 is there any way to get a directional blur (with controllable angle) that can go right to the edge of the frame without generating that soft boarder problem that is normally fixed by repeating edge pixels if one was using the box blur filter.
    I realise I could work on a larger layer size to begin with so the edges of the layer are actually outside the comps viewable area but it feels like there should be a slightly more elegant method for this.
    Graham Macfarlane
    3D animator and VFX specialist
    London UK
    Adam Rosenberg replied 9 years, 4 months ago 3 Members · 3 Replies
  • Roland R. kahlenberg
    March 8, 2011 at 7:53 pm
    Like applying Directional Blur to an Adjustment Layer that’s larger than the size of the comp/target layer?
    RoRK
    AE Training in South East Asia. AE templates for sale and rental. Click here for more
  • Graham Macfarlane
    March 8, 2011 at 11:17 pm
    What I meant was I could apply the directional blur to an oversized layer (which contains the pixels you want to blur).
    An adjustment layer would blur everything bellow which may be undesired and increasing its scale will not fix the edge problem anyway.
    Whilst using an oversized layer will solve the problem, I was just wondering if there was a more correct solution I may have overlooked.
    Graham Macfarlane
    London UK
  • Adam Rosenberg
    April 17, 2017 at 6:46 pm
    Try applying the RepeTile effect before your directional blur. Set the tiling to Unfold and increase the number of pixels to the sides that need repeated pixels.
