Activity › Forums › Avid Media Composer › direct MXF import
direct MXF import
Posted by Ian Liuzzi-fedun on March 27, 2011 at 9:49 pmI have three MXF files that I grabbed from another project. Is there any way to import them into my current project or do I need to get more files from the other project?
Ian Liuzzi-fedun replied 15 years, 6 months ago 5 Members · 8 Replies -
Michael Kammes
March 27, 2011 at 10:08 pmI’m assuming these are on 2 different machines?
If so…
You don’t “import” MXF files. You add them to the project through the media tool.
You need to add the files to the Avid MediaFiles/MXF/# folder (# being the highest numbered folder in the MXF folder).
Once you do this, Avid should scan the folder and find the file. Then use the media tool too add the file to the project.
If Avid doesn’t scan the folder, quit Avid, and delete the 2 database files in the # folder (msmFMID.pmr” and “msmMMOB.mdb”) then relaunch Avid. Avid should then find the files, and you can use the media tool to find them.
If the files are on the same machine, just from a different project, skip everything above and just use the media tool to add the files into your project.
~Michael
.: michael kammes mpse
.: senior applications editor . post workflow consultant
.: audio specialist . act fcp . acsr
.: michaelkammes.com
.: twitter: @michaelkammes
.: facebook: /mkammesHear me pontificate: Speaking Schedule .
Ian Liuzzi-fedun
March 28, 2011 at 1:29 amGreat..I found them after following your directions. How do I get them into a bin in the project I am working on.
Job Ter burg
March 28, 2011 at 8:21 amJust drag them from the media tool into any (new or existing) bin. Done.
Ian Liuzzi-fedun
March 28, 2011 at 12:20 pmI do so but the following message appears:
Some of the items arriving in this bin are currently marked not to display in this bin. The items have arrived safely.
I go through and check everything in bin preferences but still I do not see the items – what am I missing?
Michael Phillips
March 28, 2011 at 1:12 pmSounds like “set bin display” settings are set to not display master ciips. In the receiving bin, select “Set bin display” and make sure master clips are selected and active.
Michael
Michael Phillips
Ian Liuzzi-fedun
March 31, 2011 at 2:56 amAs I mentioned in previous posts – I checked everything including that. None of this worked so I just used media tool and consolidated directly from his drive without the mxf stuff. Thanks anyway guys.
