Activity Forums Adobe Premiere Pro Dip to white – am I doing it wrong?
  • Dip to white – am I doing it wrong?
    Posted by Harry Snell on May 18, 2016 at 10:44 am
    I have a dip to white between two video clips, however above the clips I have an adjustment layer. On this layer I have auto colour and auto contrast effects, and it makes the dip to white turn to strange colours.
    Is this an error, or should it happen this way.
    Is there a way to apply these effects without having to add them to each clip?
    Harry Snell replied 10 years, 3 months ago 4 Members · 6 Replies
  • Jon Doughtie
    May 18, 2016 at 2:32 pm
    Copy your sequence, so your original remains untouched.
    On the sequence copy, apply those effects to just the two clips separated by the dip to white. See if that resolves the issue.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2014 (as of 7/2015)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Harry Snell
    May 18, 2016 at 2:37 pm
    I now have around 10 clips in the sequence with dip to white, so basically that’s what I’ve done. I’ve copied the effects onto each clip instead of the adjustment layer.
    However, for me that defeats the point of having an adjustment layer. Is the dip to white meant to work that way, or is this an issue with the software?
  • Alan Lloyd
    May 18, 2016 at 3:53 pm
    Your adjustment layer is also working on the “white” in the transition.
    It’s doing what it’s supposed to do, which apparently is not what you want it to do.
    Jon’s advice is correct.
  • Gary Milligan
    May 18, 2016 at 5:44 pm
    You could also add another layer above the adjustment layer and put in a white slug where you want the dip to white to be. Then just fade it in and out.
    HTH
    Gary
  • Harry Snell
    May 18, 2016 at 8:57 pm
  • Harry Snell
    May 18, 2016 at 8:58 pm
    Thank you! I may try that as well.
