Activity Forums Apple Final Cut Pro Legacy Digitizing with a Mini DV Cam
  • Digitizing with a Mini DV Cam
    Posted by Aryn Leigh on November 7, 2007 at 5:36 am
    I’m working off of a macbook pro. I am trying to digitize mini DV through FCP, wherein the program is not recognizing the device. It does, however crash the program and any other program when the camera is turned on. It was not doing this yesterday as I digitized a good hour of tape. I’ve never had this problem before. Is it a connection problem (I.E. bad firewire), or does my FCP not like my camera??
    Aryn Leigh replied 18 years, 10 months ago 2 Members · 2 Replies
  • Paul Escandon
    November 7, 2007 at 6:32 am
    This sounds like it might be a situation where quicktime was corrupted. I would try trashing your quicktime receipts at HD > Library > Receipts (back them up before you do it for peace of mind). See if that helps.
    Paul Escandon
    Producer | Director | Editor
    Apple Certified Trainer – Final Cut Pro
    Oremus Productions
    http://www.oremusproductions.com
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Aryn Leigh
    November 7, 2007 at 7:10 am
    Hmm. No luck. The camera is behaving as though the firewire port is busted, although the computer is clearly responding when I turn the Minidv cam on and off. I am very cautious when I plug in anything firewire, so it doesn’t seem to make sense. I rarely use a device such as a camcorder so I can’t see that I overused or burnt it out. Any other suggestions??
