Activity Forums Apple Final Cut Pro Legacy digitizing issue – upgraded OSX to 10.4
  • digitizing issue – upgraded OSX to 10.4
    Posted by Mark Mann on August 28, 2007 at 7:03 pm
    hi.
    i just upgraded my OSX to 10.4.10
    I’m running FCP4.5 — now when i try to digitize, i get no video or audio — the digitize tool is reading the timecode, but says it is not recognizing the deck….
    i was running OSX 10.3.9 and it worked fine….
    any thoughts on what the problem is and how to fix it?
    17″ Powerbook, 1GhZ
    thanks
    Jeremy Garchow replied 19 years, 1 month ago 3 Members · 4 Replies
  • Walter Biscardi
    August 28, 2007 at 7:07 pm
    When making a major OS upgrade, say from 10.3 to 10.4, it is always recommended to do a completely clean install.
    This means erasing your System Drive, installing the new OS clean, running all the updates and then re-installing all of your software. This is what we do with each major upgrade and will do again when Leopard finally ships.
    Also, with FCP 4.5, ensure that it can truly run with all of the updates. Older versions of FCP oftentimes do not work all that stable with the latest and greatest versions of OS and Quicktime.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Jeremy Garchow
    August 28, 2007 at 7:26 pm
  • Mark Mann
    August 28, 2007 at 9:23 pm
    JeremyG….YOU ARE A GOD…..i’m naming my first born after you…..thanks, totally worked…..
  • Jeremy Garchow
    August 28, 2007 at 9:31 pm
    Good deal.
    God I am not. A kid named in my honor, unneccessary,
    but I am glad you are up and running.
    Jeremy
