Activity › Forums › Adobe Premiere Pro › Digitize box for DV into premiere
Posted by Mark Foerster on November 24, 2022 at 2:02 pmHi all, full of turkey yet? I’m looking for cheap box or dongle to take the dv out of a Sony dv tape player and digitize into premiere.
Mark
Michael Grenadier replied 3 years, 10 months ago 3 Members · 4 Replies -
Ann Bens
November 24, 2022 at 3:36 pmCheap usually means out of sync capture.
Best is to find a computer, install a firewire card and connect with firewire.
Now you can capture with Premiere.
Mark Foerster
November 24, 2022 at 3:49 pmYes – I still have an old Mac with a kona card installed and Media 100! – so I can do it that way. Only problem is Media 100 and all the old systems transcodes everything – then I gotta drop it in a m100 time line and export to h264
but thank you!
Ann Bens
November 24, 2022 at 8:59 pmH.264 is not a very good format for old DV footage.
If possible export to Prores 422 hq.
Michael Grenadier
November 25, 2022 at 1:26 pmor just edit natively in DV which should work fine in Premiere. You can get a firewire to thunderbolt adapter and a thunderbolt to thunderbolt 3 adapter from apple. I got this to work about a year ago going in to a 2017 macbook pro capturing both hdv and dv natively . Post back if you want the specific adapters. It may be possible to use quicktime to capture natively on your old mac… Ann’s probably got the answer to that…
