Activity Forums Media 100 Digitising HDV/DV Problems
  • Digitising HDV/DV Problems
    Posted by Peter Stewart on January 19, 2008 at 11:25 am
    I’m having problems with a Media100 HDe (Currently running v12.1.1, but problem goes all the way back to v11) when I try and digitise from a DV (downconverted from HDV) source, at the moment I’m using a Sony HDV FX1.
    I’m in PAL land, so everything I’m doing is at 25fps.
    There are periods of time when there is no problem at all and I can happily digitise for weeks and months, then suddenly it will refuse. When I go to the capture panel it insists that the source is DV/DVCPRO – NTSC, and refuses to give me any deck control.
    The problem occurs randomly and we are now reluctantly looking into purchasing a Convergent Design HD-Connect. I noticed that other people have reported the same problem, back in August, but as yet nothing has been done to fix it.
    https://forums.creativecow.net/thread/4/860273#860276
    Any help would be appreciated.
    Regards
    Peter Stewart
    Freelance Editor (UK)
    In Production : Legacy of War (ITV/WNET), Imaginary Summer (Feature Narrative)
    Michael Slowe replied 18 years, 7 months ago 3 Members · 2 Replies
  • Kieran Matthew
    January 19, 2008 at 11:39 am
    Hi Peter,
    Yes, this is an ongoing issue, not helped by the fact it seems to be a PAL problem, and that it only affects certain decks. The M25E, for example, doesn’t seem to suffer from it.
    Perhaps if we, as a community, could list all the decks/cameras we have had problems with, it would give Media 100 something to go on.
    For me, as mentioned in the other thread, it was an M10E.
    K
  • Michael Slowe
    January 19, 2008 at 12:42 pm
    Peter, yes I find that on the occasions I need to edit in SD I still take my HDV from my M10 deck, (firewire from deck, SDI into Media 100) as HD which I obtain through the Convergent Design HD-Connect as you suggest. This works perfectly with machine control and I then downscale if required within Media 100. Media 100 does not like getting DV from these HDV decks.
    Michael Slowe
