Activity Forums Apple Final Cut Pro Legacy Digitbeta Output – Print vs Edit to tape
  • Digitbeta Output – Print vs Edit to tape
    Posted by Ashley James on September 8, 2006 at 4:40 pm
    This board has been a tremendous help. I’m almost finished with my first big FCP project. We want to dump to digibeta. There is a debate about which method will give the best quality. One expert says Print to Tape, the other says Edit to Tape.
    Which method will give the best quality?
    Thanks ahead of time.
    Ash
    Mac Dual 2.3 PCI-X
    4.5 gb Ram
    Kona LS / AJA IO
    FCP 5.1.1
    Nick Price replied 19 years, 11 months ago 3 Members · 2 Replies
  • John Christie
    September 8, 2006 at 4:43 pm
    They are both the same in terms of quality. Edit to tape will control your deck however, which you’ll need to do to get frame accurate output to tape. Print to video is just like doing a crash record, you can’t control the deck with it.
    Cheers
    John C
    Keyframes Editing
  • Nick Price
    September 11, 2006 at 5:33 pm
    Ashley,
    print to tape is just like pressing play. It has no real use for my money. Edit to tape enables you to record frame accurately onto dvcam/digibeta using timecode. If you want to run off a VHS dub press play. To create a master on digi, edit to tape.
    best wishes
    nick
