Activity › Forums › Adobe After Effects › Digital Real Time clock
Posted by Anandabrata Ghosh on October 13, 2007 at 9:11 pmHi All,
I need a digital clock which will give the real time . It will give the time for various countries. Say the real time in US is 10 AM , the clock should show the real time, if the time for another country , say France is taken at the same moment. The clock should be able to display the real time wrt to US.
I need your suggestions/inputs for the same.
Regards,
AnandSam Moulton replied 18 years, 10 months ago 5 Members · 5 Replies -
Steve Roberts
October 13, 2007 at 9:39 pmI’m not sure what you want. After Effects makes video clips that have no relationship to the current time. Those clips cannot access any signal from a clock and update it in real time.
I think you need something like a Flash or Javascript applet on a computer hooked up to the Internet, no?
Jerzy Drozda jr
October 14, 2007 at 2:34 amIn fact you’re right Steve. Even if it would be possible to do it would make no sense, unless someone wants to know when the movie was rendered 😉
But because I am AECracker and ExpressionJunkie I’ve actually found a way of getting the CURRENT TIME on a local computer in after effects.
I’ll do some more experiments on it and make a sensible response to this post. Maybe even a tutorial 😉
Cheers
Maltaannon
maltaannon.com – Free After Effects Video Tutorials and more
Mike Clasby
October 14, 2007 at 2:50 amDefinately a Flash thing. Here’s how:
https://www.dreamincode.net/code/snippet137.htm
Then publish a swf and you should be good to go.
Anandabrata Ghosh
October 14, 2007 at 5:25 amHi,
To start with my apologies for my post wasn’t specific enough.
Let me try and consolidate.
1) First I need a digital clock on my video which will display the real time/machine time.
I have been able to achieve that, here’s how
a) Use the Text –> Numbers effect.
b) Choose Format -> Type as Time
c) Check the Current Time/Date box
d) Decide the positionAnd the clock appears on the video and ticks at real time.
Shortcomings – I would have like more options with the font and styles of the text.2) Second I need two such clocks on the same frame(all frames of the video actually).
The first one will display the machine/current time. Point (1) achieves that.
The second clock will display time from a different time zone.Now that is what I need help with. In this effect I have only the Cuurent Time/date option. Is there some way I can choose time for particualr time zone.Hence when I view the video I will be able to see two times, relative to each other. For example US and France.
Hope that clarifies my requirement.
Regards,
Anand -
Sam Moulton
October 15, 2007 at 5:01 amcheck out the global options in the Expression language menu. There are a bunch of time to timecode prewritten expressions that you can simply apply to a text layer. You’ll have to use a monospaced font to keep from having the numbers jump around though.
