Activity › Forums › Apple Final Cut Pro Legacy › Digital Juice Sound FX III not working
  • Digital Juice Sound FX III not working
    Posted by Vincent Strader on September 9, 2008 at 10:37 pm
    I’m trying to import sound efx from Digital Juice Sound FX III . When I bring them in and lay them down on the time line it shows up as 3 audio tracks. It will not render to play back, and I only get the unrendered audio noise. When I double click on one of the sounds , instead of the graphic showing up in the canvas, the canvas drops down.
    Has anybody else tried using these, and if so, did they work?
    Thanks for any info,
    Vinnie
    Miriam Moran replied 18 years ago 2 Members · 1 Reply
  • Miriam Moran
    September 11, 2008 at 1:35 am
    I have not used the Sound FX but I have used the Stak Trax (and many of their other products). Here’s a few guesses –
    Do you have the correct version of the “juicer” ? I think it’s version 3.0(something) currently. Be sure your updates are current.
    Check your settings you used in Juicer – be sure you selected the right settings for your FCP project.
    If you haven’t figured it out – contact their technical support – I’ve only had to call them a couple of times, but they have been extremely prompt and courteous in their help.
    Good Luck!
