Activity › Forums › Apple Final Cut Pro Legacy › Digital Juice Juicer And Prores 444
Posted by Erik Naso on April 13, 2010 at 10:25 pmProRes444 is a great codec and I want to use it with the Digital Juice Juicer program. For some reason when I try to use it it makes a blank QT file. Anyone use the Juicer for ProRes444? I know I can use compressor for this and that is what I did do, But it sure would be nice to preview and convert in one place.
Erik Naso replied 16 years, 3 months ago 4 Members · 7 Replies -
Michael Gissing
April 13, 2010 at 11:03 pmI presume you have FCS3 because that codec wouldn’t be on your system for Compressor to use so if it working there then it points to Juicer. were you using a standard frame size like 1920 x 1080 or is this 2K or higher frame sizes or non standard?
I suggest you contact Digital Juice.
Erik Naso
April 14, 2010 at 1:27 pmFCS3 And 1920 x 1080. I contacted DJ and they suggested I reinstall the prores codecs. Not sure about that. So I wanted to see if anyone has the same problem.
https://www.mediaartproductions.com
Mark Maness
April 14, 2010 at 2:37 pmWhat version of Jucier do you have? Is it the latest?
_______________________________
Wayne Carey
Schazam Productions
https://web.mac.com/schazamproductions
schazamproductions@mac.com -
Erik Naso
April 14, 2010 at 2:50 pm -
Mark Maness
April 14, 2010 at 3:49 pmHave your repaired your permissions?
The error you speak about sounds like something could be wrong in the permissions. If not, check and make sure of your render settings inside of Juicer.
Wayne Carey
Schazam Productions
Aaron Randerson
July 2, 2010 at 7:36 pmDid you ever find a solution to this issue. I now have the same issue even the it had previously been working. Suddenly I only get empty QT files.
thanks in advance! -
Erik Naso
July 2, 2010 at 9:06 pmNever could get this to work on two systems running snow leopard.
