Activity Forums Apple Final Cut Pro Legacy Digital Juice Files Jaggy
  • Digital Juice Files Jaggy
    Posted by John K on January 31, 2007 at 4:22 pm
    Just got some of th Editor’s Toolkits from Digital Juice and need to use one this week for a High School Basketball broadcast. I loaded the files I want into FCP to do a test and after the rendered the animations seem awfully jaggy. Any ideas? I am using this in SD, 29.97. The animations look good but I know they should be much smoother. Thanks for any help or insight you can provide.
    John J. Klimkiewicz
    On Site Video Production Services
    David Roth weiss replied 19 years, 7 months ago 3 Members · 2 Replies
  • Mark Maness
    January 31, 2007 at 4:26 pm
    What is your Easy Setup?
    “Jaggies” depend on your compression settings within your sequence. And another thing to look at, what type of files are these? Are they HD or SD video? I do know from experience that sometimes with animation files that are encoded using the anaimation codec and you need to use them in a DV sequences, you’ll see these “jaggies”.
    Something to look at…
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • David Roth weiss
    January 31, 2007 at 7:27 pm
    [John Klimkiewicz] “I loaded the files I want into FCP to do a test and after the rendered the animations seem awfully jaggy. Any ideas?”
    Most important of all, how are you monitoring? On a computer screen or an NTSC monitor or TV?
