Activity Forums VEGAS Pro Digital audio vs analog audio output for broadcast
  • Digital audio vs analog audio output for broadcast
    Posted by Jordan Brulotte on April 25, 2009 at 1:43 am
    Hello,
    I have a project going to broadcast, and I was asked to submit it with the audio levels at “-20db digital”. I work with Vegas and with all my past broadcast projects I have set my peak audio levels to just under and never exceeding zero on the meter. After doing a ton of reading I am still confused…
    What would “-20db digital” be on Vegas’meter? The more I read the more confused I get.
    Jordan Brulotte replied 17 years, 4 months ago 3 Members · 4 Replies
  • John Rofrano
    April 25, 2009 at 6:52 pm
    It would be… -20dB because the Vegas meters are digital.
    If the quiet parts in your program are too low at that level, one thing you can do is put Wave Hammer Surround on the final output and set the Output Level on the Volume Maximizer tab to -20dB to ensure that you don’t go over. Then you can play with the Threshold to make it sound louder and still maintain the -20 dB level.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jordan Brulotte
    April 25, 2009 at 9:23 pm
    That is what I thought, however when the project got to the broadcaster they told me the levels were way too low, and that I went -20dB analog and not -20dB digital.
  • Douglas Spotted eagle
    April 26, 2009 at 2:33 am
    They would be right, most likely.
    Tones should be -20dBfs, which may or may not match their meters, depending on which standard at which they are calibrated.
    Be sure there is not more than 12dB of dynamic range overall (assuming this is dialog priority)
    If you’ve set your max volume at -20dBfs, I sure hope your source masters are hotter than that! Otherwise, when you boost it to a -6/=3dBfs peak then your S/N will be pretty poor.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Jordan Brulotte
    April 26, 2009 at 2:48 am
    In the past others have requested that my tones reflect the peak signal, therefore I set my peaks to -20dB… I knew right away would be very low but I figured that’s what they asked for. I guess there was a miscommunication when I asked for their specs and got the sole response of “-20dB Digital audio”. They must have meant JUST the tones.
    As a rule of thumb, what is the proper peak and mean levels in dBfs for broadcast submission in North America?
    Thanks for the help!
