digidesing 001 and Sony Vegas
Posted by Alfredo on August 31, 2005 at 12:06 amhi everyone:
does someone knows if vegas support any audio recorder hardware like
Digi 001 or 002 0r any other, Thanks.
Alfredo Ornelas.
Gary Kleiner replied 21 years ago 3 Members · 4 Replies -
David Sheneman
August 31, 2005 at 2:08 pmI use the 002 with Vegas 5. All you have to have is the wav drivers from Digidesign installed on your computer and it works fine. You don’t even need to have ProTools installed on your system. It shows up as an ASIO device and you can record from any input – up to 18 total if you use the mic & line inputs, ADAT optical inputs and the coaxial SPDIF inputs simultaneously. I’ve recorded up to 16 tracks simultaneously (didn’t need the SPDIF input on that project) with no problems to an internal drive on a laptop (7200 RPM, though).
David Sheneman
Technical Director
Rockford First Assembly
Rockford, IL
daves@rfa.cc
815-877-8000 -
David Sheneman
August 31, 2005 at 2:09 pmI haven’t tried the 002 control surface to see if I can get it to control Vegas through MIDI. Does anyone know if it’s possible to map the buttons, knobs & faders to control parameters inside Vegas? That would be cool. I know it supports the Mackie control protocol, but it also works with general MIDI commands as far as I know. Anyone know or have experience with it?
David Sheneman
Technical Director
Rockford, IL
daves@rfa.cc
815-877-8000 -
David Sheneman
August 31, 2005 at 7:07 pmI have to correct myself a little. There are separate ASIO drivers from Digidesign that you must install. The wav drivers allow non-ASIO aware programs to use the 002 as input/output.
David Sheneman
Technical Director
Rockford, IL
daves@rfa.cc
815-877-8000 -
Gary Kleiner
August 31, 2005 at 11:05 pm[David Sheneman] “Does anyone know if it’s possible to map the buttons, knobs & faders to control parameters inside Vegas?”
That should be very doable.
Gary
