Activity Forums Apple Final Cut Pro Legacy DigiBeta / Playback Offset varies between HD and SD source.
  • DigiBeta / Playback Offset varies between HD and SD source.
    Posted by Mike Lary on October 9, 2012 at 5:48 am
    Printing to DigiBeta from FCP 7.0.3 and Kona 3 (drivers up to date), I have to adjust the playback offset by one frame every time I switch between HD source and SD source. This happens consistently. It’s not a big deal, but I’m curious as to why this would be happening.
    Mike Lary
    Digital Factory
    Seoul, South Korea
    Mike Lary replied 13 years, 10 months ago 3 Members · 3 Replies
  • Michael Gissing
    October 9, 2012 at 5:57 am
    The Kona has a frame delay in the down convert. You can set a frame delay in the edit to tape window by using the in/out time code and subtracting one frame.
  • Baz Leffler
    October 9, 2012 at 11:00 pm
    ….AND…. there are different settings in device control for SD and HD.
    With my Multibtridges it if 5 frames for both.
    Baz
  • Mike Lary
    October 10, 2012 at 1:46 am
    Thanks, Michael. That makes perfect sense.
    Mike Lary
    Digital Factory
    Seoul, South Korea
