DigiBeta Output has Audio Distortion
I’m trying to output a sequence to DigiBeta, and I’m having audio distortion issues on the tape when I play it back.
It’s about a 30 minutes sequence that I’m running to tape using the “Edit to tape…” feature. I’m coming out of FCP with my Kona LHe and running the audio and video through SDI into the Digi deck. The audio sounds fine when playing it in FCP, and it sounds fine when monitoring it from the deck’s headphones. I just has the deck serviced/cleaned yesterday to attempt to fix this problem, but it still persists.
When I play back the DigiBeta (brand new tape) the channel condition indicator light will go from green to red on the spots in the sequence where there are issues. (This sequence is a compilation of several :30 spots.)
I ran a test to see if there are just certain :30 spots that are giving me trouble and it made things more complicated… I ran a :05 portion of the sequence to tape directly (played from the timeline without using “Edit to tape…”) and the audio sounded good on it, and the channel status was good too.
All drivers and software are up to date, I’ve rebooted, and also checked all cables to make sure they are plugged in all the way. I’ve trashed FCP prefs too.
Any thoughts?
