Activity › Forums › Apple Final Cut Pro Legacy › DigiBeta is recording everything 1 frame early
  • DigiBeta is recording everything 1 frame early
    Posted by Adam Taylor on September 7, 2006 at 12:06 pm
    I have a problem with my set up that i haven’t managed to figure out.
    I’m using FCP5.1 on a Quad G5 with 4gb ram, 3.5TB raid, Kona 3 video card, Snell & Willcox sync/burst, Sony DVW-M2000P.( I’m working 25fps pal)
    I am connected up through SDI and am finding that the Digibeta is recording 1 frame early.
    I set my timeline to start 09 58 00 00 for bars/tone/clock, with the ads starting every 2 mins on 10 00 00 00 / 10 02 00 00 etc.
    the in point in edit to tape is set to be identical (09580000).
    When i jog back through the Digi – every single clip starts 1 frame early. I cannot find any info about what needs to be changed and on which device.
    The Kona shows the RP188 (sdi) timecode as being 1 frame ahead of the timecode the digibeta is showing. I have tried offsetting this 1 frame either way and it makes no difference.
    I have tried setting the ref in on the kona to either ref in or video in – no difference.
    I have looked through the DVW manual but not found anything obvious.
    Anyone have any clues as this is driving me nuts!!
    thanks
    adam
    Walter Biscardi replied 20 years ago 2 Members · 3 Replies
  • Walter Biscardi
    September 7, 2006 at 12:09 pm
    Sounds like your Deck Control offsets need to be adjusted. that’s what those offsets are for.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Adam Taylor
    September 7, 2006 at 12:23 pm
    thanks Walter,
    spot on advice…I knew i had seen that dialog box once before but could not remember where or what it was called. It seems my settings had a rogue +1 frame in the playout offsets. Now it don’t, and it works correctly.
  • Walter Biscardi
    September 7, 2006 at 12:32 pm
    Gotta love the simple stuff. Glad you’re up and running.
